VI says Not Responding When Trying to Save
What is the compiled code complexity? Most likely it is doing a recompile after your code changes (no matter how minor). If the diagram is large and contains many inlined subVIs, this can be expensive. Do you separate compiled code?
Message 11 of 12
(421 Views)
Good point Christian!
Wasn't there an issue with an earlier version of LV where code changes were extremely slow as long as the project was open?
Q
Does it save faster if you just work with the VIs open and not the project?
What version of LV are you using?
Do you have "auto-populating folders" turned on?
Ben
Message 12 of 12
(417 Views)
