VI server registration error
I have a VI-based server in DSC 7.1, and I try to upgrade to DSC 8.0.
I followed the instructions from NI, but I cannot register the VI server with the registration VI.
I get :
Error -1967362038 occurred at an unidentified location
Possible reason(s):
IAK_SHARED:  (Hex 0x8ABC700A) Not found.
can anyone explain this error?
(3,189 Views)
Hi, i suggest you file this bug to the support at national instrument.
However as a help, this means that either your server or device inside the server is not being registered correctly. One possibility is that the device name used has xml special characters in it.
One way to check it is to check the xml file that gets generated. You should find them in Program Files\National Instruments\Shared\DSC|VI Based Server\8.0\ directory. There should be 2 files, one is DSC Server.xml and if you open this you should see the server you just registered.
The other file is the server file itself, open this and see if you have malformed device name or property.
You could always attach the two XML files and the registration VI data for your server.
(3,168 Views)
Hello:
  Thanks for the post. Could you please post your registration and XML file. It will be very helpful to us. We shall be able to look in to the issue.
Thanks and have a great day
Avi Harjani
(3,156 Views)
