VI shown as broken but LabVIEW does not identify where the error is
I pick up a LabVIEW project from another developer who is not in a position to help. The main VI is broken and LabVIEW (both 2017 and 2015 environments) shows several sub-VI’s that are broken (not executable) in the Error List.
Now at the broken sub-VI’s level, clicking the broken arrow points back to the same broken sub-VI in the Error List (LV should show where the error is in this VI instead!). Also, clicking on each individual lower level sub-VI of the broken sub-VI… LV shows that all the lower level sub-VI's are good. WHY?
Has anyone ever run into this issue? I am a new LabVIEW user (1 year).
(3,009 Views)
Hi Dan,
why don't you attach your VI?
Or, at the very least, show an image of the error dialog?
(2,991 Views)
Hi GerdW
Thanks for the suggestion. I thought about doing the same thing. Here is a zip file that contains 6 screenshots for the following actions:
1. 1-main-vi-Capture: Main VI – broken
2. 2-error-list-Capture: Error List showing where the errors are for Main VI
3. 3-sub-vi-broken-Capture: Front panel of the 1st broken sub-VI
4. 4-pointing-to-same-sub-vi-Capture: Double click on broken error brings back to the same VI in the Error List
5. 5-sub-vi-broken-block-diagram-Capture: Block diagram of 1st broken sub-VI… I made sure the STOP condition is taken care of for all cases
6. 6-lower-level-sub-vi-good-Capture: Double click on the lower level sub-VI shows that each one of them is good
Dan
(2,968 Views)
Hi dan,
images of frontpanels are pretty senseless…
The only interesting part is that error message about those dynamic dispatch VIs of classes in image 2: you need to debug all your class hierarchy!
(2,959 Views)
