VI simulate input drivers
I need to use LabVIEW to process data from an input device, but then I need to get the output from LabVIEW into Windows (eg, like x and y mouse coordinates). Does this mean I need LabVIEW to communicate with a "dummy" mouse driver or is there a more convenient solution?
(3,983 Views)
LabVIEW has built-in functions for getting data from input devices, like mice. However, I don't quite understand what you mean by "need to get the output from LabVIEW into Windows". Can you provide details on what you mean by this?
(3,974 Views)
I need LabVIEW to emulate mouse events in Windows, just as if it were acting as a mouse driver. I don't know at which level it should do this at, can LabVIEW emulate a kernel mode driver? Or would it be better to just send messages to Windows about mouse events?
(3,963 Views)
You can call the Windows API functions "SendMessage", "PostMessage", or "SendInput" (an older function) to send messages to Windows, such as a mouse move. You should also take a look at this KB article. Also note that the convention call to use should be set to "stdcall (WINAPI)" in the configuration window for the Call Library Function.
(3,956 Views)
I'm interested in doing the same thing. What KB article are you referencing? There is no link. Thanks.
(3,896 Views)
(3,891 Views)
I don't really like the way LabVIEW handles a lot of the structures used by the Windows kernel, so I wrote a wrapper DLL that simplifies the intialization and outputs.
Essentially:
26 WINAPISENDINPUT_API int fnWinAPISendInput(long x, long y, DWORD flags)
27 {
28         UINT cInputs = 1;
29
30         MOUSEINPUT mouseInput =
31         {
32                 x,      // LONG dx
33                 y,      // LONG dy
34                 0,      // DWORD mouseData
35                 flags, // DWORD dwFlags
36                 0,      // DWORD time
37                 0       // ULONG_PTR dwExtraInfo
38         };
39         INPUT input =
40         {
41                 INPUT_MOUSE,    // DWORD type
42                 mouseInput              // MOUSEINPUT mi
43         };
44         LPINPUT pInputs = &input;
45         return SendInput(cInputs, pInputs, sizeof(input));
46 }
(3,880 Views)
