VI start/end events?
I have an application in which i need to execute some events when the main vi is open/closed (closed as in the user clicks the top right corner 'x'). Is there any event i can use for this?
Message Edited by Gordal on 05-18-2010 03:05 PM
(3,336 Views)
Accepted by topic author Gordal
You would use the <Application> Application Instance Close? and/or the <This VI> Panel Close? filter events.
Jim Kring has a nice blog entry on this subject:
Controlling the Exit of Built Applications
(3,326 Views)
Are there similar ways to do this in non-built applications? When developing.
(3,314 Views)
Yes.  Select <This VI> instead of <Application> when adding a new event.  Some sub-selections for This VI are:  Key, Mouse, Menu, Panel Close, Panel Resize.  Select Panel Close to capture when someone clicks on the X in the upper right corner of the front panel.  You can use Panel Close? to trap the event and wire a True to the discard terminal to prevent the user from closing the panel with the X.
You can also use <Application> - Application Instance Close? to trap when a user clicks on File - Exit.
Message Edited by tbob on 05-18-2010 01:55 PM
- tbob
Inventor of the WORM Global
(3,301 Views)
Does it have to be event based?
it coulb be as simple as a state machine architecture
Startup State->Main Code->Shutdown State
Paul Falkenstein
Coleman Technologies Inc.
CLA, CPI, AIA-Vision
Labview 4.0- 2013, RT, Vision, FPGA
(3,261 Views)
Based on the original poster's question, yes.
A state machine by itself can't capture events such as the application close, you need to use the event structure.
(3,229 Views)
