VI stuck running cannot get to diagram
I created a program and added EXIT to it. When I run LV to edit the program I can't get to the block diagram because it automatically runs on start and the EXIT button exits LV. How do I get out of this so I can edit my program? :0)
(2,765 Views)
Drop the VI as a subVI on another VI's diagram and then you can open it and edit it.
Good luck,
-D
(2,760 Views)
Have you tried Ctrl+M while it is running?
Now Using LabVIEW 2019SP1 and TestStand 2019
(2,737 Views)
