VI takes forever to load
Dear all,
  I am facing problem to load the attached VI. Can one let me know why is it not loaded?
Too, I will like to learn, what should I do if this is happening again.
Thank you
BR
Vincent
(2,854 Views)
There is nothing special with that VI.  It opens , loads and runs at a normal speed, which means fast.
It behaves normally with me.
Is this the only VI you see this behavior?
(2,850 Views)
Dear Ray,
  In fact, any VI that involves this subvi will not load for me. Smiley Sad
(2,838 Views)
We need more information.
Does it start searching for it? Does it simply hang? Is your LabVIEW version lower?
(2,830 Views)
It should work fine... There's practically nothing inside that VI.  And it's something that is used regularly.
As Altenbach mentionned, we need more info.  You'll have to do a bit of investigative work..
(2,820 Views)
Ray and Alten,
  I found I couldn't even load any serial example
I am trying to unintall LV and see if it helps, and get back to you. Thanks for your prompt reply 🙂
(2,816 Views)
Is VISA installed?
Lynn
(2,814 Views)
