VI taking time to load first time
why My VI is taking so much (at least 4 minute) time to load not to run?
(2,563 Views)
And the Great Karnak says:
What will be today's question with no information whatsoever given to allow someone to even a chance to guess at what the problem might be?
And we have a winner!
If you want real help, provide real information. Like what your VI is doing. What toolkits you are using. What operating system you are using. What version of LabVIEW you are using. Whether you have any controls or indicators with saved data, like graphs. You might want to take a gander at this: How To Ask Questions The Smart Way
When you provide the information, get back to us. In the meantime, we'll be over there in the corner doing absolutely nothing except waiting for you.
(2,541 Views)
He'll be busy answering his telephone-
It not a good idea to use personal information as your user name.  You can change the display name by selecting the My settings" link in the light blue navagation bar
(2,532 Views)
  • Like what your VI is doing.
  • What toolkits you are using.
  • What operating system you are using.
  • What version of LabVIEW you are using.
  • Whether you have any controls or indicators with saved data, like graphs.
...a few more...
  • What LabVIEW version is the VI? Is it the same as the version you are using.
  • Are all subVIs in the expected locations or does is constantly search when loading?
  • Was the VI last saved on a different platform (Mac, Linux, 64bit windows, non-sse2, etc.)
  • Are you using LabVIEW 2011 on an computer that does not support sse2 (e.g. athlon XP, pre-pentium 4)?
  • Does your VI use mathscript?
  • How much free memory does your computer have?
  • Are the VIs and subVIs local or on a network location?
  • Are you using addons (openg, toolkits, etc.) that are not masscompiled?
  • What else is running on your computer?
  • Do you have large folded structures that need to be computed at compile time?
  • Is your VI set to seperate compiled code?
  • Do most VIs (e.g. examples from the example finder) load much faster?
If most of the questions don't apply and you think it should load much faster, please attach your VI.
(2,528 Views)
