VI time measured through the profile performance
Hi all,
My app works not so fast as usual and I decided to measure time with the profile performance tool. But times in a report are much less then the real times. What is the matter?
(3,098 Views)
In order to help you better to resolve this issue I would like to know what version of LabVIEW you are using. How much are the times off by and how are you determining the run time of your actual VI? You may want to get a timestamp at the start of your VI and another timestamp at the end (in LabVIEW code) to make this comparison.
Abhinav T.
Applications Engineering
National Instruments India
LabVIEW Introduction Course - Six Hours
Getting Started with NI-DAQmx
Measurement Fundamentals
(3,080 Views)
Abhinav T,
Thanks for reply. I'm using LV 8.2. And as you purpose, I measure actual time by two timestamps at the beginning and the end of VI.
(3,064 Views)
Did meauring the timestamps give a more accurate time?
Abhinav T.
(3,053 Views)
Hi again,
Total time for my VI, measured by Profile Performance tool is approx. four times lower than the time, measured by timestamps (actual time, in other words).
(3,042 Views)
Can you post your VI? I would like to try this out.
Abhinav T.
(3,036 Views)
Sorry for long silence. Here are my subVi's in attached files. They are parts of the big project and will not work by themselves. The subvi's work with one queue at the same time, but GetData.vi completes 100 while loops pretty faster than Dequeue&Graph.vi. It must be noticed that FastCorrection and Statistic connectors for Dequeue&Graph.vi were False during examination. When GetData.vi had stoped after 100 while loop cycles, Dequeue&Graph began to work faster, and I set this vi's to be executed in separated threads. But nothing have changed.
Screenshot is attached also. Waiting for you comments.
(2,977 Views)
