VI to Track position with a Rotary Encoder using NI9401??
I am very new to LabView, and I need a VI to track radial position (0-360°), using a rotary encoder.  It is 2000 pulses per revolution. and there is a phase shift when direction changes.  Any ideas? I am using labview 2009.
(3,099 Views)
Steven:
What hardware plugging the 9401 into?
The examples for doing encoder measurements are located within the LabVIEW example finder.
In LabVIEW, go to: "Help --> Find Examples" to open the example finder.
From there, browse to: "Hardware Input and Output --> DAQmx --> Counter Measurements --> Positioin."
Hope that helps! Robot Happy
Caleb Harris
National Instruments | http://www.ni.com/support
(3,079 Views)
She is plugged into a NI cDAQ-9172.
Thanks for your help.  I will see what I can accomplish from here.
(3,072 Views)
