VI to measure hall resistivity using keithley 920 system
Hello Folks,
    I have an old keithley 930 series hall measurement system. The keithley instruments are older than the current one and while they all function perfectly they require commands through the GPIB interface that are more specific that the current instruments. I'm wondering if anyone has such a program written to measure the hall properties (essentially just current voltage measurements) using this system and if I could have a copy.
Thanks in advance   Smiley Wink
Will.
(2,747 Views)
Apologies that should be a 920 series hall system!!!
(2,742 Views)
Hi Will,
You should take a look on the NI Developer Zone Instrument Driver Network at:
http://www.ni.com/devzone/idnet/
I've found a couple of Keithley drivers but I didn't see anything specifically for 920 series:
http://sine.ni.com/idnetwork/main/p/sn/n25:IK.keithley
You might want to try to use a driver for a similar model if you can find one.
Regards
Way S.
NI UK Applications Engineer
(2,727 Views)
