VI using a dll buildt on an other PC causes MSVCRTD.dll missing error
When I open a VI that uses a self buildt DLL that was fine on the Computer where I buildt it (with Visual C++) on a differnt computer I get the following message:
"This application has failed to start because MSVCRTD.dll was not found. Re-installing the application may fix this problem."
(Well, re-installing did not fix the problem)
I had to write a dll to do a time consuming task efficiently but I am not an expert in doing it...
I would appreciate any help.
Andreas
(3,333 Views)
Well if your custom DLL calls routines that are located in MSVCRTD.DLL then it works fine when Visual C++ is installed because that DLL was installed with Visual C++.  When you take the DLL to the new computer without Visual C++ it won't work because you didn't also copy MSVCRTD.DLL.  Since I'm guessing you have no need for Visual C++ on your other PC, you could just copy the file over with your DLL.
The other thing you could try to do is remove the MSVCRTD.DLL dependencies from your custom DLL (if that's possible), so it won't need to be loaded.
(3,332 Views)
Thanks, I tried this first but I copied it obviously to the wrong location. Now it is in windows\system32 and everything works fine.
Thanks again,
Andreas
(3,327 Views)
Just so you know, the MSVCRTD.dll is a debug build of the C runtime library. It isn't installed on computers without VC++ because it is assumed you aren't debugging on those computers. You need to change the build spec for your DLL to be "Release Build" and then the dependency will go away. Most systems already have MSVCRT.dll installed so you shouldn't have a problem.
Note that this should also speed up the system as debug builds are typically unoptimized and have extra checking included.
(3,311 Views)
So that's what the "D" stands for 🙂 Excellent info Brian.
(3,304 Views)
