VIPM 2025.3 quits after loading
Hi
I have upgraded VIPM to version 2025.3, but after loading it , the program just quits. Has anyone experienced something simliar ? It looks like some issue with file persmission
=========== START of VIPM 2025.3 (build 2805) Error Message ===========
An internal VIPM 2025.3 (build 2805) Error has occured on: Wednesday September 03, 2025 at 09:56:31 PM
= Automated Message Start =....
....>OGPM Class.lvlib:OGPM Init.vi->VIPM Splash.vi
Possible reason(s):
LabVIEW: (Hex 0x8) File permission error. You do not have the correct permissions for the file.
DMA hardware error detected.
C:\ProgramData\JKI\VIPM\cache\Spec Database Datalog.sdd
= Automated Message End =
= User Defined Message Start =
Error(s) Generated in Splash Window
= User Defined Message End =
= Error Handler Call Chain Start =
VIPM Splash.vi
= Error Handler Call Chain End =
=========== END of VIPM 2025.3 (build 2805) Error Message ===========
(804 Views)
I was able to uninstall this version and install a previous version 2024.1 that worked !
(760 Views)
