VIPM Browser Download Issue - JKI EasyXML
I recently installed a fresh install of LabVIEW 2020 and VIPM.
I have been trying to install JKI EasyXML. It doesn't find it on the main window of listed packages, so I then select the search online button which pulls up the VIPM Browser. It locates EasyXML on the browser window. When I select it, instead of showing "Install" in the bottom right, it shows "Download". When I select "Download" it rapidly shows a loading screen then disappears.
Where does this download supposedly go? I would have thought it would update the list of packages in VIPM's main window but it doesn't appear there.
I've tried "Download" multiple times. I've uninstalled VIPM and reinstalled an older version 2020 SP1 and it still doesn't work.
Really need this toolkit to get some code working to flatten and unflatten clusters to actual XML format and not LabVIEW XML format. Would appreciate the help. Thanks
Message 1 of 1
(12,695 Views)
