VIPM detected that LabVIEW Version 2019 is required to build your package
Hi All,
Before Windows 10 64b update to 1909 everything worked smoothly.
After the update, I am experiencing strange problem when building a package using VIPM 19.0.
I had installed LV version from 2016 to 2019, and the package meant to be build for 2017. When starting the build, VIPM opens LV 2019 and complains about not having installed VIs for 2019. Those VIs are installed for 2017.
So I uninstalled LV 2018 and 2019, and now getting this dialog:
Checked the version of the VIs in my .lvlib, all of them are 17.0. Version of the dependency package is installed for LV 2017, and support is >=10 so that should be ok.
I am wondering, does anybody have experience with this or have some recommendations how to solve this?
Duri
(2,097 Views)
Accepted by topic author Duri
I made a mistake and saved control from 2019 to the other project used to build package and controlled only *.vi and not *.ctl.
So no problem with the win update nor with VIPM
Duri
(2,028 Views)
