VIPM download issues
Hello I just downloaded the Labview Student edition and was having issues with the VIPM. I redownloaded it using this link:
http://www.ni.com/gate/gb/GB_EVALTLKTARDUINOCOMP/US
After redownloading the VIPM I am getting this error message attached. I am not sure what else to do at this point hope someone has a solution. Thanks
(1,749 Views)
Which LabVIEW version are your using? Because as per the error you need runtime engine of 2015. I guess there is a conflict between LabVIEW version and VIPM
CLD Using LabVIEW since 2013
(1,723 Views)
I am using Labview 2020
(1,697 Views)
VIPM uses LabVIEW, and needs to link to a compatible version of LabVIEW.  It is doubtful that, as clever as JKI is, they could predict, in 2015, how to build VIPM that would be compatible with the version of LabVIEW being used five years in the future.
I believe that you can download the free version of VIPM 2020 from jki.com.  You can also do a Web search for VIPM, which will probably guide you through the process.
Bob Schor
(1,688 Views)
