VIPM: pkg build aborted: "The following source VIs or Libraries are missing" (xpost from JKI forums)
Hey folks-
I hope this is not 'illegal' with respect to forum rules or anything, but I was thinking some of you that might be able to provide some insight on this might not necessarily be lurking the JKI forums as much as NI's...
http://forums.jki.net/topic/1718-pkg-build-aborted-the-following-source-vis-or-libraries-are-missing...
I've wasted many hours trying to figure this out... Robot Mad
thx
-pat
(2,564 Views)
Re: Rules
You're OK in my book since you dclared it a cross-post.
It stops us from wasting our time trying to answer what has already been answered.
Sorry i can help with the QSM issue.
Take care,
Ben
(2,548 Views)
Thanks for the confirmation, I can't say I figured this issue out yet, but I did get it to build a new package somehow... so I'm ok until I need to update the package ...
-pat
(2,538 Views)
Hello Pat,
I'm not familiar with VIPM, but you should probably leave any packages you're trying to use in LabVIEW installed.
If you want to keep debugging this, you should make a dummy project or copy of your current project and try building that.
Colden
(2,533 Views)
