VISA -1073807312 error(ERROR ABORT) in VISA READ
Running Labview 6.1 winXP.
Have a program that amongst other things regularly communicates via the COM PORT to an external device. Works well, except every so often(I would say every 1/10 attempts), I get a -1073807312 error in the VISA READ vi. According to the documentation this is a ERROR_ABORT. A possible reason is given as user abort.
There is no user intervention during communication.
Any idea what could be causing this?
Thank you for the help.
(3,728 Views)
check if "termination character" enabled or not. May be you receive termination character which aborts the communication.
Good luck.
Oleg Chutko.
(3,728 Views)
Hi, thanks for the speedy reply
I am pretty sure the termination character is disabled. I use the standard VISA CONFIGURE SERIAL PORT vi. There I set ENABLE TERMINATION CHARACTER to FALSE. However I only do this when my program initializes. Should I be doing this before every attempted serial communication?
And if it was TERMINATION character causing the problem why do I get an error?(Surely then I should have a successful READ with incomplete data)
Thanks again for the help.
(3,728 Views)
Try to check your communication with this nice software:
SysInternals PortMonitor:
http://www.sysinternals.com/ntw2k/freeware/portmon.shtml
(disclaimer: I'm not sure how it works under WinXP)
(3,728 Views)
Run NI-Spy in the background. Check for any calls to viTerminate, which can be used to abort a VISA read, which will in turn return a User abort message. Also unless you have multiple VISA sessions doing I/O at the same time, try changing your VISA VIs to synchronous VIs (right click and select "DO I/O Synchronously").
NI Spy Tutorial
(3,728 Views)
