VISA Array Broken Wire
One way is to use the Array of double you got from my previous answer, and use a function array to cluster. But you need to tell LabVIEW the Size of the Cluster.
on the diagram right click on the array to cluster function and select the size of hte cluster (3)
Message 11 of 12
(504 Views)
one more thing, you don't need to wire to a local variable inside the loop, wire it directly to the cluster indicator
Message 12 of 12
(503 Views)
