VISA Communication - Losing data from string
The port exists in my device manager...I do not have or know what the measurements and automation center is.
Message 31 of 36
(1,471 Views)
That's Measurement and Automation Explorer.  We refer to it as MAX.  It is a program used to configure all of NI's hardware.  You can also see what serial ports, GPIB instruments, and the like you can communicate with.  It should have been installed with VISA and LabVIEW.
Message 32 of 36
(1,466 Views)
NI MAX should be installed on your desktop.
Your VI is setup to read/write once. You aren't doing something like clicking the Run Continuous button are you? If you are, stop.
Message 33 of 36
(1,464 Views)
Thanks, found it. It does exist there also. I'm not sure what the problem with this program is..I keep getting the same error.
Message 34 of 36
(1,462 Views)
No, I am not doing that.
Message 35 of 36
(1,458 Views)
Anything change since it was last working okay?
Have you shut down and rebooted?
Message 36 of 36
(1,444 Views)
