VISA Error -1073807202 Pls help
HI all,
When I am trying to run the VISA Example vi in the labview library I am getting an Error -1073807202 which says "
Possible reason(s):
LabVIEW:  (Hex 0xBFFF009E) VISA or a code library required by VISA could not be located or loaded.  This is usually due to a required driver not being installed on the system.
Can anyone tell me what I am doing wrong. I have all the Instrument I/O Trial Version toolkits. Where can i find the drivers for it.
Nitz
(3,597 Views)
You can find teh install for teh VISA run time libraries here: VISA run time
Mark Yedinak
Certified LabVIEW Architect
LabVIEW Champion
(3,585 Views)
