VISA Error 1073807202 when running standalone .exe on another PC
When creating a stand alone application (.exe) it does run successfully on a coworkers PC. I've installed the LV RT engine and the vi loads but then stops and displays the 1073807202 error. I read about possibly needing new visa drivers but do not know where to find them if this is in fact the issue. Also, how do I attach a file to this message? The "Add Attachment" button below hasn't worked for me for days. Regards, Chris
(2,722 Views)
VISA drivers can be found on the Device Drivers CD/DVD. You can also download them from here.
I have not encountered problems adding attachments. Did you try another browser? Could be a browser issue.
(2,718 Views)
