VISA Find Resource - illegal operation
Hi. I have a completed labview application that has a problem. The
program is rather simple - it just queries the board, using VISA Find
Resources, and writes to a text file what it found. It works fine.
However, after you shut down the labview program (after running my
program), it causes an illegal operation. By using the process of
elimination, I discovered that the VISA Find Resource is the problem.
Eliminating everything but that one command will still cause the illegal
operation. If you open up labview, and insert in a VISA Find Resource
(or the Easy VISA Find Resource), and then close the program, there are
no problems. However, if you run the program that simply has the VISA
Find Resource, then when you
exit out of Labview entirely, the
crash occurs.
BTW, I'm on Windows 95.
Sent via Deja.com http://www.deja.com/
Before you buy.
Message 1 of 1
(2,785 Views)
