VISA: (Hex 0xBFFF0015) Timeout expired before operation completed.
I am new to lab view and i am using a Tektronix 3014B o-scope, I downloaded the driver pack from the NI site and am connecting through TCPIP on a local network when i first ran the examples that were included it worked fine for only 5 runs then i get this error and have not been able to get the examples working again. No changes were made when this error happened.
i have attached the error dialog box. when i tryed to trace it down i think it is comming from the VISA read but do not know how to fix.
Labview 7.1
Jared
(4,969 Views)
Have you tried power cycling the oscilloscope. I have had this issue with a tektronix 3034. If any of the settings on the front panel of the scope are changed while the driver vi is running I have gotten this error. The scope does not automaticlly lock out the front panel controls when it is being remote controlled. Every time this error has come up I have had to power cycle the scope.
Andrew Alford
Production Test Engineering Technologist
Sustainable Energy Technologies
www.sustainableenergy.com
(4,960 Views)
