VISA: (Hex 0xBFFF0015) Timeout expired before operation completed.
Mr Kartiknattar,
is it possible is not a program's problem?
Because i already having reading TimeOut error at VISA Test Panel.
Message 11 of 16
(1,191 Views)
The time out error is because you are trying to read 1024 bytes of change change it to 50 bytes in visa test panel you will not see any error.
Also try the read command in visa test panel if you are getting the output or not
CLD Using LabVIEW since 2013
Message 12 of 16
(1,178 Views)
Okay, I feel we haven't even gone over the basics.  Let's do this:
(This WILL work.  Notice - no termination character.  You don't need one when writing to anything other than a COM port.)
Better yet, just save yourself some additional heartache by bopping on down to the driver page on the NI Instrument Driver Network and use that instead.
Bill
CLD
(Mid-Level minion.)
Message 13 of 16
(1,170 Views)
Hi, another doubt.
when i changed the byte to 50.
and command is *IDN?\n   (which means Identification Query, according to manual)
and in VISA test panel,
if i click: 1. Write -> OK, 2. Query -> OK, 3. Read -> TimeOut ERR
but if i click 1. Write -> OK, 2. Read -> OK,
why when i click Read after Query will have time out ERR ?
Message 14 of 16
(1,165 Views)
Hi Mr Bill
i run the basic program you send, if the Visa write and Visa Read both have no Error.
Can i assume that the labview and equipment is communicating well,
and do not have hardware or driver issue ?
Message 15 of 16
(1,160 Views)
A Query is a Write followed by a Read.  So you just need to click on Query.  You might be confusing the instrument by sending the command twice and then attempting to read twice.
Message 16 of 16
(1,147 Views)
