VISA: (Hex 0xBFFF001D) The specified attribute is not defined or supported by the referenced resource.
Hello ,
This error message came in the Visa interactive tool  : VISA:  (Hex 0xBFFF001D) The specified attribute is not defined or supported by the referenced resource.
what should i do to fix it   ?
Thanks !
regards ,
bibo702
(4,162 Views)
Don't define that attribute. The device appears to be a PXI card. There is no VISA timeout.
Mike...
Certified LabVIEW Architect
LabVIEW Champion
(4,132 Views)
Mike ,
I cant do any modification in this window . how should i proceed ?
regards
bibo702
(4,125 Views)
Hi bibo702,
you try to set a timeout for a PXI-1031 Chassis. A PXI chassis doesn't support a timeout value.
It is not possible to set a timeout, independent of the software you are trying to use.
Stephan
(4,090 Views)
