VISA Read Doesn't Appear to Work
Hello Good People:
I am fairly new to LabVIEW, currently trying to simulate a GNSS /GPS receiver display using a virtual COM port and VISA protocol. To test the VI, I picked a randomly created NMEA sentence in GPGGA format, and used it as a string constant as an input to VISA Write's write buffer.
In the attached screenshot, the output from the VISA Write correctly shows the byte count, but the output from the VISA Read (return count 2) is always zero. It doesn't seem to read anything that is being written to my COM port. The read buffer output is also blank. What am I doing wrong here?
Thanks a lot in advance!
Message 1 of 16
(2,163 Views)
A serial port is not a buffer. (EDIT: well it is, but not one FIFO buffer).
What you write should be handled by a device connected to the com port. The device should reply, and that can be received by the sender.
Or did to connect the COM Rx and Tx (2 and 3 IIRC), to create a loop? That would be required. That would have been important to mention...
If you want to create a simulator to test an application, you can use com0com to connect a virtual com port to another com port (or TCP\IP).
Message 2 of 16
(2,152 Views)
Almost every serial port communication problem through VISA can be usually solved after watching this video and learning what is mentioned in there.
https://labviewwiki.org/wiki/VIWeek_2020/Proper_way_to_communicate_over_serial
Rolf Kalbermatter  My Blog
Message 3 of 16
(2,149 Views)
Sorry, botched that link:
VIWeek 2020/Proper way to communicate over serial
Message 4 of 16
(2,126 Views)
Ignore this
Message 5 of 16
(2,105 Views)
I do not have actual physical com ports on my laptop. So I used an emulator software to create two virtual com ports (COM1 COM2) which are currently paired. My NI MAX also displays these virtual ports on the left pane.
Message 6 of 16
(2,051 Views)
I’ll be watching it now. Thank you very much for this pointer.
Message 7 of 16
(2,049 Views)
Thank you very much. I look forward to learning from it.
Message 8 of 16
(1,988 Views)
One of the takeaways of that video is probably that you shouldn't use bytes at port (,at all or only in very specific cases).
When you write the data, it will take time to get the reply, so right after the write there are 0 bytes at port, so you'll read nothing.
It's always better to rely on end termination characters, and for NMEA, that's certainly the way to go.
Set the count to read way to high, use a reasonable time out, and let the end termination characters decide when the message is complete.
Message 9 of 16
(1,947 Views)
Funny you mentioned this. I modified the code a bit to write to COM1 and put it in a producer loop. Then I created a second while loop (consumer) and made the 'read' operation to read from COM2. The data is then displayed properly. I have virtual COM ports where COM1 is paired to COM2.
Message 10 of 16
(1,823 Views)
