VISA Read Timeout Error (-1073807339) with Axetris MFC-2252 (RS-485 Full-Duplex)
@chabazite  ha scritto:
I hope that works for you
Your vi can be improved under some aspects, but basically seems ok to me.
So, either the device address is not 1 or the RS485 connection is defective.
As per my experience, 90% of the communication issues with RS485 are due to a wrong cabling (typically D+ and D- swapped).
Paolo
LV 7.1, 2011, 2017, 2019, 2021
Message 11 of 15
(77 Views)
Do you still get a timeout ?
When using VISA for RS485 connection, I normally have to configure the RS485 part manually.
Set the wire type of the RS485 with at property node on the VISA wire.
Message 12 of 15
(62 Views)
actually for my case it is 4 wires (full duplex), in which there are no D+ and D-
Message 13 of 15
(52 Views)
This actually multiplies the probability of an error, generally speaking.
Paolo
Message 14 of 15
(40 Views)
Yes right, there are R+, - and T+, - . I will try different device address and also some solutions dkfire recommended. Then I will share again if there is still problem
Message 15 of 15
(36 Views)
