VISA Reconnecting and even disconnect, wait for connect.
we made some board, and this board uart disconnect during some situation,
i would like to know how to keep my visa.... even if short disconnect.. now, if there is dis connect, error will be comming and stop visa and stop loop.
is any body can help me about this?
1 more thing.... im keep wait for get respons of visa.. and few read data is not same byte... how can i wait and get any deffrent byte,,
>>> visa open >>> wait >>> few time later, 5byte... >>> few moment later , 20byte...>>> few moment later >>>10byte.. >>
now i try to learn, and tcp visa revieving problem always make me hard to do so ^^;;
(437 Views)
Hi junseok,
Implement some error handling and close/re-open the VISA port when your "disconnect"-event occurs…
Implement the messaging protocol of your device correctly, so you don't need to worry about varying byte counts! (Bad suggestion: Read one byte after the other with a small timeout value. When a timeout error pops up you know the message is complete.)
Watch this video to learn all you need to know about serial communication with LabVIEW!
(415 Views)
