VISA Resource Name alias to integer
I need to "convert" a VISA Resource Name alias an integer that will passed to a Call Function Node input parameter.
For example, COM1 will result in 1.
So far I have wired the VISA Resource Name to Format Into String then wire that string into Scan From String.
Is there an easier way.
(5,093 Views)
You can use VISA property node to get this information (and other informations, like "is it serial port?").
(5,047 Views)
Thank you for this. I learned something new.
(5,027 Views)
Hi, is there a way to do this in the other direction? I will use Labview for a plugin in a other program. For this I need for input only a integer variable, e.g. the number of the COM Port. Is it possible to convert this then in a Visa Ressource name?
BR Martin
(2,903 Views)
Hi Friese,
Simple like this:
(You can wire strings into VISA resource inputs…)
(2,900 Views)
Hi Gerd, thank you for the very (very) fast response:-)
I found in the last minute my own solution.
So both works. Thank you again.
BR Martin
(2,889 Views)
I do something similar to GerdW.
NOTE: That Set Termination Settings is my own VI, so don't go looking for it in the palettes.
(2,874 Views)
