VISA Serial + Arduino
Hi guys, maybe you remember me from an early post asking why my messages from LabVIEW to Arduino were truncated... Now I'm back with this issue:
I managed to "separate by lines" the full "too long string", but the thing is that the message is truncated in the same way than before... But I realize that growing the delay between sending each line, the Arduino received more and more lines from the total string. The thing is that I can't make this delay grow much more than 1 second, so I was wondering... if this happens because of the Arduino Buffer... can I "flush" the buffer or something? if yes, WHERE should I put this flushing thing?
I know that VISA offers "VISA Flush I/O Buffer" and "Visa Clear", but I'm not sure how to use them, at least, by now, none of them works for what I want to...
PS0: I'm attaching a picture of the SubVI that I'm using to write line by line
PS1: Sorry for my english, I hope you understand
PS2: Background: I'm sending "G-Codes" through LabVIEW interface to an Arduino using a RAMPS SHIELD (used for 3d printers) and "too long" G-Codes were truncated exactly at 200 characters (Early Post)
Thanks!
(4,772 Views)
Accepted by topic author lord_nox
If the problem is on the Arduino buffer, then the only thing you can do on the LabVIEW side is send the data at a slower rate.  Your issue is on the Arduino side.  Concentrate on fixing that (read data faster, increase your buffer size).
(4,765 Views)
Its not the first time that someone told me about the limit is from the Arduino... I did check this and in my program I set the Buffer Size from 4 bits to 64 bits (I know that it's not the best option, but it works!)
(4,717 Views)
Bits?  or Bytes?
(4,707 Views)
I think you mean 4 Bytes to 64 Bytes.  4 bits (0, 1) is 1/2 of a Byte (0-255, 8 bits).  A single character is a Byte.
(4,704 Views)
