VISA TCP/IP can not open session
Hi all!
I'm trying to made a communication between two computers through TCP/IP protocol. I create New VISA TCP/IP Resource, choose Manual Entry of Raw Socket, enter IP address and Port Number and have next error:
What is the solution to this problem?
Message 1 of 10
(8,731 Views)
Help me, please
Message 2 of 10
(8,727 Views)
Why don't you just use the normal TCP/IP functions? I'm not even sure you can talk to a non-VXI-11 device with VISA. You've got numerous TCP/IP examples, pick one.
Message 3 of 10
(8,696 Views)
VISA TCP will work with any generic TCP device.
Also, to the OP your resource name is incorrect. It should be TCPIP::<IP Address>::<Port>::SOCKET.
Mark Yedinak
Certified LabVIEW Architect
LabVIEW Champion
Message 4 of 10
(8,686 Views)
@goodboycowboy wrote:
Hi all!
I think you're a bit confused.  Are you trying to do this?
Bill
CLD
(Mid-Level minion.)
Message 5 of 10
(8,684 Views)
You said you are trying to establish a communication between two computers, but in your example the client and the server address are the same. This leads me to think that you misunderstood the concept of creating a VISA resource. When you create with address x.x.x.x and port y, MAX tries to connect to that port as a client. It doesn't create a server.
The operation you are trying to do can be successful if there is actually a TCP server waiting on the same computer at port 50000, though.
Paolo
LV 7.1, 2011, 2017, 2019, 2021
Message 6 of 10
(8,676 Views)
Accepted by topic author goodboycowboy
Okay. I've never used the SOCKET type.
Message 7 of 10
(8,667 Views)
Thank you for responding!
used only TCP/IP functions. All works=)
Message 8 of 10
(8,630 Views)
please i'm facing somesing like that ,i'm trying to control tegam 1830 power meter to labview but when using visa write function i have error
and when using TCP\IP  functions i don't know what to connected to tcp open function in port i\p
please any help
Message 9 of 10
(7,855 Views)
Hello e.gtoto88,
The original post to this forum has been resolved. I would suggest posting your question in your own forum page as the question you are asking is very different from the original post. Asking your question in your own forum page will make is easier for the community to help you.
J_Bou
Message 10 of 10
(7,816 Views)
