07-05-2023 06:56 AM
I was wondering if I could receive help with this error I am encountering. I double checked everything to ensure it wasn't a common error (as far as I can tell). My baud rate and everything matches with the current system running, and the RS232 is working correctly. Also, the vi was working correctly with no errors prior to today. If anybody has tips, that would be great.
07-05-2023 09:23 AM
Make sure no one has messed with your setup while you were away - like turning off the equipment, for instance. It's happened to me before.
07-06-2023 10:24 AM
It's usually in frequent use. However, it's quite odd that it happened out of the blue. I am wondering if this could be a result of the read buffer being 134 and the sent command being 6 as that's the only other error within the vi.
07-06-2023 11:45 AM - edited 07-06-2023 11:48 AM
I am missing subVIs. Can you attach subVIs? It's hard to tell debug, but have you tried using "NI Visa test panel" to check if it's working? Can you attach the real code? You mentioned baudrate, but when I open your attached code, I don't see where you are setting baudrate.
07-07-2023 06:28 AM
I attached the driver as a zip file, that will have all the necessary vis. I should mention that this is not my work, it is a watlow driver found on LabVIEW that I have been trying to run but have had no luck with.
I have used the Visa test panel and it was all working, the image I provided previously was showing that the COM port was working with a loop back test. The Baud rate is set in NI MAX along with in the settings of the device, so it was never needed to be defined in the vi. I am not entirely sure what you mean by the real code, my apologies.
I have also tried to read the data through a separate COM port with PuTTY but it is in ASCII and I am still trying to convert it.
07-07-2023 08:01 AM - edited 07-07-2023 08:07 AM
Actually, not that hard to debug. Why oh why did you set the end mode for reads property to none while expecting a response terminated with a CR? you'll timeout every time. None means no termination condition.
Get rid of that property node! Or, at least set it to Term Char and set the Term Char value to CR ( expand the property node and select the term Char property.)
