VISA Write sends continuously
OK this has gotten interesting.  Time to RTM Smiley Wink can you link to the users manual or provide the model number for the Flame Ionization Detector.  We must have miss-understood the command structure.
here is the LV10 version Mo
Message 21 of 32
(2,450 Views)
Thanks Jeff.  RTM (Read The Manual)?  Where is this detector mentioned (or is this an inside joke I am unaware of)?  Perhaps I missed something.
So let me get this straight.  Is the OP claiming that 0x11 is being sent repeatedly with this code? Just trying to get a handle on his problem as well as understand the apparent impossibility of that happening.  But then I've seen many apparent things that can't be explained.  The code runs as expected for me; although, I have not sniffed out the serial port to see what's happening there.
Reese, (former CLAD, future CLD)
Some people call me the Space Cowboy!
Some call me the gangster of love.
Some people call me MoReese!
...I'm right here baby, right here, right here, right here at home
Message 22 of 32
(2,442 Views)
@MoReese wrote:
Thanks Jeff.  RTM (Read The Manual)?  Spot on
Where is this detector mentioned (or is this an inside joke I am unaware of)?  Perhaps I missed something.  OP in post 1 mentions FID
I bet it will make perfect sense when we figure it outSmiley Surprised
Message 23 of 32
(2,436 Views)
The only thing that would explain it is if he is pressing run continuous. I asked above but still have not seen an answer. (Or a weird driver problem with the virtual serial port. I have never used or heard of a virtual serial port)
LabVIEW 2012
Message 24 of 32
(2,434 Views)
Steve,
I bet thats a Virtual COM Port as in a usb to rs-232 VCP
Message 25 of 32
(2,429 Views)
I have not been pressing "Run Continuously."
The virtual serial port isn't a USB-RS232 adaptor; it is a program that creates a "fake" serial port on your computer to provide a destination for testing programs that use serial communications without actually connecting to the device.
I've attached the manual for the FID, the communications info is in chapter six.
Message 26 of 32
(2,422 Views)
Thanks for the manual and the explaination on the VSP target (I've never used one either-and won't speak for its reliability)
with the vi in its current state you write 0x11 ^Q "start data stream" and the term character 0x0A which is not recognized be the device.  Change the term char enable to F and "Bob's your uncle" - or at least you wrote the code to spec!  the true test is targeting it to real hardware.  then you'll see how close the tech writers got to what the engineers produced.  (You'ld be surprised how often that breaks down)
Good luck!
Message 27 of 32
(2,417 Views)
Gatekeeper, did you ever find out what was going on?
LabVIEW 2012
Message 28 of 32
(2,391 Views)
Not yet, I've been pulled away from the project by more important work.  I should know sometime next week.
Message 29 of 32
(2,387 Views)
Finally got back to the project.  It turns out I hadn't installed the NI-VISA package.
Seems obvious now, but it wasn't included as an option on the installation discs - I had to download the package from NI.  Also, the VISA functions are included in the development environment even without the package installed, and that's what threw me for a loop.
Message 30 of 32
(2,356 Views)
