VISA Write
Hi friends, i just want to send a numeric value say 40 through serial port to another device at 460800 baud rate, could you please help me what conversions should i made ?
Message 1 of 8
(3,082 Views)
Hi Akbar,
use VISA functions to access the serial port.
How do you want to transfer this "value of 40"? Human-readable text, binary data, any message formatting?
Message 2 of 8
(3,079 Views)
i just want to simulate battery voltage say 40V on serial channel
Message 3 of 8
(3,042 Views)
That didn't answer the question.
Let's ask the question a different way.  What is the device on the other side you are sending the data to?  What does it expect the data to look like?
ASCII characters of "4" and "0"?  Should it have a termination character like a line feed or carriage return?
Is it a single byte of value 40?  (That would be an ASCII character of an open parenthesis "("  ).  Multiple bytes?
Message 4 of 8
(3,035 Views)
Shameless plug to give you ideas:  VIWeek 2020/Proper way to communicate over serial
Message 5 of 8
(3,031 Views)
the device on the other side is also receiving serial data which i am sending what type of scaling do i use ?
Message 6 of 8
(3,026 Views)
Accepted by topic author Akbar7110
Hi Akbar,
Read the manual of the "device on the other side" to learn about the communication scheme supported...
Message 7 of 8
(3,020 Views)
Message 8 of 8
(2,955 Views)
