VISA and READ function - Problem linked to the bytes at port
Ohhh well, should I take back that remark about the plumber? Smiley Surprised
Probably not! Smiley Very Happy
Rolf Kalbermatter  My Blog
Message 31 of 114
(1,938 Views)
Here is a cleaner version of my code
Thank you all for your help 🙂  I've rarely seen such an helpful community
Flo
Message 32 of 114
(1,934 Views)
Since the vast amount of users posting questions to the forum are new to LabVIEW, we try to make it a learning experience as well.  🙂
Bill
CLD
(Mid-Level minion.)
Message 33 of 114
(1,930 Views)
I can't see the data type of the integer in the typecast function.  make sure it's u8 or the conversion won't work correctly.
Bill
CLD
(Mid-Level minion.)
Message 34 of 114
(1,918 Views)
I've got something maybe:
47 = my termination character. It seems that if I don't add a VISA Flush I/O Buffer I get it working 1 time every 2 runs.
Message 35 of 114
(1,917 Views)
Adding that property node is exactly like using the termination stuff on the VISA Configure Serial Port VI, so it must be that you were doing the typcasting incorrectly.  And yes, I had already mentioned not using that flush thingy.  😉
The manual says: Optionally, a carriage return may be used to indicate the end of a transmitted string. A received carriage return will cause the pump to immediately respond to the received command, and may help speed communications.
So you should tack a carriage return to the string you are sending so the pump doesn't have to wait around and guess that you are done sending the command.  This will probably take care of that "every other" thing you were talking about.
Bill
CLD
(Mid-Level minion.)
Message 36 of 114
(1,910 Views)
I'll try with the carriage (so, I just have to replace my 47 by a 13 isn't ?).
The thing is that without the flushing thing, the code doesnt work anymore!
Message 37 of 114
(1,908 Views)
Sorry for confusing you.  The command sent in the VISA Write should have a carriage return attached to the end of it.  The VISA propertynode I think was okay, if not maximally efficient.  😉
Bill
CLD
(Mid-Level minion.)
Message 38 of 114
(1,903 Views)
Yes replace with a 13, but also you can flush the IO, but you should put a delay after the flush, use the time delay function(Which is in seconds) so you can have data dependancy before the write.  I would suggest about 100ms.
-Matt
Message 39 of 114
(1,901 Views)
Also remember that if you screw up the serial reading by sending bad data, you may have to reset the pump to get it to work right again.
Bill
CLD
(Mid-Level minion.)
Message 40 of 114
(1,900 Views)
