VISA communication problem
In my application i have communicated controller with the labview via serial communication with USB Serial cable (using VISA tool). My application works perfectly fine in development mode and in.exe(without installer)
Problem starts when I create the installer the communication starts malfunctioning. The communication behaviour is unpredictable. I have included different additional installer associated with VISA while creating my installer, the attached image shows it. Tell me if I am missing any additional installer. Some of the thread says that I should be having NI-Serial which is actually not listed in my case in the additional installer list.
The problem is that my application on target device (which is not having labview) is not taking certain commands. Guide me with this please. Thank you
Message 1 of 20
(4,663 Views)
Guys.... I would really appreciate help on this ..
Message 2 of 20
(4,627 Views)
hi
can you connect to application in debug mode and check whats going on inside? you dont need labview on target pc.
http://forums.ni.com/t5/LabVIEW/how-to-run-labview-in-debug-mode/td-p/74636
On your exe projcet you need to enable debug mode and wait for debuger to start, then you have to open labview on your pc and Operate>Debug Application>put ip and connect
best regards
http://www.krzysztofszewczyk.net
Message 3 of 20
(4,618 Views)
I am not sure but i think if you are using a controller ... Don't you think you need to generate C code from LabVIEW code ..... when you go to File<<VI Properties  ... you have option there for generating code for ARM andother controllers..
Message 4 of 20
(4,612 Views)
what?
Message 5 of 20
(4,609 Views)
Well....a littel doubt in my mind. I developed all the VIs on labview 2011, but by mistake I opened it in labview 2012 and made installer and everything on labview 2012 only. Does it have to do anything with this?
Message 6 of 20
(4,597 Views)
In my experience, there is little risk in updating your VIs to a newer version; it's when you go backwards that you begin to have issues.  That being said, maybe There are some options that are different between the two LabVIEW versions?
I know it's too late for this project, but have several versions of LabVIEW on the same (Windows 7) PC, and I've opened up projects in the wrong version even though I selected the project from the --> menu from the correct LabVIEW version on the Start Menu.  It seems that the shortcut will open in the last version of LabVIEW that you had open, even if you did what I did above.  Now I explicitly open the correct LabVIEW version and select the project from inside LabVIEW instead.
Bill
CLD
(Mid-Level minion.)
Message 7 of 20
(4,570 Views)
How do i convert my VIs back into 2011 version from 2012?
Message 8 of 20
(4,549 Views)
File>>Save for Previous Version
Also refer to:
KnowledgeBase 203EDCXC: Can I Save VIs in My Current LabVIEW Version for Use in a Previous Version?
http://digital.ni.com/public.nsf/allkb/DA470EB199497F4086256931007050C0
A quick search on NI.com or Google will often save you time.
Tom L.
Message 9 of 20
(4,544 Views)
Put one error indicator and see what is going on.
Kudos are always welcome if you got solution to some extent.
I need my difficulties because they are necessary to enjoy my success.
--Ranjeet
Message 10 of 20
(4,538 Views)
