VISA delay
I'm sending data to a st mc and the mc sends back the exact same message and are comunicating using visa read/write and uart. The data stream is continuous and im using a special character to measure the round trip time. Im expecting some delay but the total delay between sending and and receiving is usually more than 4sec. Is there a way to reduce this time? The mc is just receiving and sending back.
labview -> mc seems to be instantaneous (VISA Write -> Uart_receive), the slow is prob in the mc -> labview (Uart_transmit -> VISA read).
The baudrate, com port are the same, visa write expects one byte, everything in a 1ms while loop, no termination character
(1,363 Views)
Hello SUIP,
what does "st" and "mc" mean?
4 seconds delay seems very long. Have you tried "Serial Write and Read on Two Ports.vi" from the Find Examples- dialog in the Help- menu?
Greets, Dave
(1,353 Views)
Sorry I didn't specify, I'm using a stmicroelectronics microcontroller, I'll check using the vi you mentioned
(1,341 Views)
Share your code. We have nothing to go by until you do. But my gut feeling is that you are not properly using a termination character as the 4 seconds sounds like a timeout.
(1,296 Views)
Accepted by topic author SUIP
Most serial communication issues can be solved by watching this video: VIWeek 2020/Proper way to communicate over serial
=== Engineer Ambiguously ===
(1,277 Views)
