VISA driver for Agilent N9010A-507 EXA Signal Analyzer LabVIEW - NI Discussion Forums
Hi
We need the VISA driver for Agilent N9010A-507 EXA Signal Analyzer for LabVIEW 7.1..
How can i find it?
Bülent Sert
Message 1 of 12
(4,995 Views)
Is this what you are looking for?
You can find it in the Instrument Drivers Network, which can be found on the Support and Community tab of the NI homepage.
Hope this helps
Dave
Message 2 of 12
(4,989 Views)
Hi Dave,
Thanks alot for your an information.
When i download the  agmxa_setup file ,will i control the  Agilent N9010A-507 EXA Signal Analyzer from GPIB for Labview 7.1 ?
BR
Bülent
Message 3 of 12
(4,979 Views)
After downloading the correct driver and VI's that supports LV7.1, you will need to interface with the instrument.  This is usually done using GPIB or serial communication.  Some drivers include a set of examples.  Agilent is usually provides one or two examples.
RayR
Message 4 of 12
(4,970 Views)
Thanks alot
You are right,it has 2 examples for Labview 7.1..When we buy the  Agilent N9010A-507 EXA Signal Analyzer , i can ask more question.
Best Regards
Bülent Sert
Message 5 of 12
(4,965 Views)
Because that is an IVI driver, you will also need the IVI Compliance Package like it mentions on the driver download page. You can configure the IVI driver in MAX (Measurment & Automation Explorer). It will be up to you whether to use the IVI class drivers or not.
Message 6 of 12
(4,946 Views)
Hi
i am downloading the ICP320.exe . How can i see the ICP's old version name  in the Labview?  i downloaded the agmxa_setup.exe which is VISA driver for Agilent N9010A-507 EXA Signal Analyzer for LabVIEW ..
are the ICP320.exe  and agmxa_setup.exe   enough to control the Agilent N9010A-507 EXA Signal Analyzer ?
Best Regards,
Bülent
Message 7 of 12
(4,939 Views)
The exe's have to be run and after the installation is complete, you can double-check the version of the IVI compliance Package in MAX. The version is also given on the download page that I gave you.
Yes, you can control the signal analyzer.
Message 8 of 12
(4,935 Views)
thanks
Message 9 of 12
(4,927 Views)
Hi
How can i create the labview result screen to html file?
Bülent
Message 10 of 12
(4,843 Views)
