VISA plp tti power supply
 Hi everyone,
I have a reception problem of data of my power supply TTi pl303-P
I tested the communication via Ni MAX, and no pb, it works properly when i send *IDN? it answer me right.
But as soon as i want do the same with a VI, there is no display in the read buffer...
here my code
i tested without "\n", with an open serial VI, change the byte count, ... No display while i haven't message error
I even did a test with the instrument assistant and it worked...
Please help, thanks in advance.
EDIT: i use the V14.0
V.T
(3,937 Views)
Hello ,
could you try this example  ?
https://forums.ni.com/t5/Example-Code/VISA-List-all-VISA-Devices/ta-p/3504571
Cordially
Ingénieur d'Application | (NI France)
(3,879 Views)
What error is returned?
Add one of the Error Handlers to the end of your little VI and tell us what it says.
=== Engineer Ambiguously ===
(3,863 Views)
Hi RSTLVU,
my error: http://prntscr.com/atna0s (1073807339)
i already test to solve it with the "why do i receive the error 1073807339 in Visa ..." dedicated to it...
(3,838 Views)
Hi Arnaud_G
I ran it : http://prntscr.com/atnbph
ASRL 5 is the port COM where my unit is connected.
(3,834 Views)
I finally choose the facility by using an USB/Ethernet adaptator ...
Thx!
V.T
(3,805 Views)
