VISA property not present in LabVIEW 6.0.2.
VISA property "Serial Settings>Break Length" not available.
I created a VISA Property node then attempted to select the property from the popup list.
Thanks for any reply. :}
(3,029 Views)
Which version of VISA is installed? I think this property wasn't available until VISA 2.6. LabVIEW 6.0.2 is shipped with an earlier version. Upgrade VISA and you'll be able to use the property.
LabVIEW, C'est LabVIEW
(3,029 Views)
I had installed VISA 2.6 and looked for the property in both LabVIEW and VISA Interactive Control with no luck.
I did find the property in a header file. "C:\VXIpnp\WinNT\include\visa.h". Have no idea what it's there for other than maybe a macro for use with C progromming or CVI.
I will try uninstalling VISA and give it another try. Thanks for the response.
(3,029 Views)
I had the same problem about 1 year ago. This was the answer from NI :
It turns out that when you update to NI-VISA 2.6.0, we do not actually update the visarc file in the LabVIEW 6.0x directory. We will try to fix that in a future version of our installer. For now, just copy the attached file into your LabVIEW\resource directory.
(3,029 Views)
Thank you JB! That fixes it. :}}
Thanks to others who replied also.
(3,029 Views)
