VISA resource help
Over the last year I have been using a number of USB components that, to LabVIEW, look like COM ports.
My VISA Resource name now has 150 COM ports listed
Even though I only have 3 listen in MAX. Is there a way to clean out the VISA Resource pull down menu,
or have it list just then COM ports names that are in MAX?
(3,930 Views)
Right click the VISA resource control and select I/O filtering.
Under the general tab, the alias box should be check marked.  Select "Only for resources that VISA finds".
2006 Ultimate LabVIEW G-eek.
(3,920 Views)
I should have clarified and I am sorry
I need to do this in LV 7.1 and 7.0 as well.
There is no I/O filtering in 7.1 or 7.0
(3,914 Views)
Go old school and manually fix the visa ini file at in C:\VXIPNP\WinNT\NIvisa
the file is visaconf.ini
under the [aliases] section you can remove old resources - make sure the Numalias value gets changed to reflect the new number.  Save a backup first, and do this w/ MAX and LV closed.  You can even delete the whole file, open MAX and F5 to rebuild it.
(3,903 Views)
To clean everything out, with MAX closed, you can delete the file called visaconf.ini (c:\VXIpnp\WinNT\NIVisa if I remember correctly), then start MAX and do a refresh.
(3,902 Views)
Thanks that solved the problem
(3,867 Views)
