VISA resource name constant
Hello all,
I'm working with LabVIEW 6.0.2 on Windows 2000 service patch 2. I have
two machines - one a development workstation, the other a portable.
They are not the same machine, but both are fast pentiums running the
same OS and LabVIEW version as mentioned above.
When I insert a "VISA resource name constant" into the wiring diagram
on my development workstation, I can use the manipulation cursor (the
hand) to select COM1, COM2, or LPT1. If I do the same thing on the
portable computer, I get different choices - the visa resource names
ASRL1::INSTR, ASRL2::INSTR, and ASRL10::INSTR. Such constants created
on one machine and then exported to the other create errors, although
they work on the machine in which they were created.
Why is
this happening? Right-clicking on the constants, they have the
same properties; under "Select VISA Class" and then "I/O Session",
"Instr" is checked. Nothing else is checked except "Size to Text".
These properties are the same on each computer.
Dan Greenspan
Mail Stop 14-707M
Johns Hopkins University
Applied Physics Laboratory
11100 Johns Hopkins Road
Laurel, MD 20723-6099
240-228-7490
daniel.greenspan@jhuapl.edu
(3,401 Views)
"ASRL1::INSTR" is the resource name and "COM1" is the alias of one and the same resource.
Probably no aliases are defined on your portable computer. Launch the Measurement & Automation Explorer and choose menu Tools->NI VISA->Alias Editor (I hope thats the right translation, because I use the german version). Here you can define an alias for every VISA-resource. These alias-names will then shown on your "VISA resource name constant".
Christian
Test Engineering
digades GmbH
www.digades.com
(3,401 Views)
My guess is, on the development workstation, some aliases have been setup for those Visa Resources, eg COM1 is an alias for ASRL1::INSTR.
If you look in Measurement and Automation Explorer under Devices, you can tell if this is the cases.
Regards
Ray Farmer
Regards
Ray Farmer
(3,401 Views)
