VISA session to an instrument handle
I tried to aquire data from TEKTDS 220. I use "set condition" to "aqu
status",
then "read waveform" subVIs. So there is a problem: I need to connect the
"VISA
session" to "instrument handle", but it doesn't work. Could you please tell
me
how to connect these two type of wires?
Thanks a lot!
(3,270 Views)
It looks like you're trying to mix the tktds2x0 IVI driver with the tktds2xx LabVIEW native driver. The IVI driver has an "instrument handle" which is an IVI session, and the LabVIEW driver has a "VISA session". The two wires are not compatible. You should either use just the IVI driver or just the LabVIEW driver.
(3,270 Views)
I undertand! I am a beginner, so I was really frustrated when writing my first VI. Your answer helped me a lot. Thank you very much!
(3,270 Views)
