VISA tcp/ip
Now, my instrument can be communicated with LABVIEW In the MAX. However, when i use the serial VI, it will come a error.
Error -1073807331 (0xBFFF001D)The specified attribute is not defined or supported.
(3,008 Views)
Accepted by topic author yao_yong
Presumably you are referring to this post: http://forums.ni.com/t5/Instrument-Control-GPIB-Serial/can-not-find-the-instrument/m-p/1637728?
I thought you were trying to communicate via TCP/IP. Why are you using the serial port example?
(2,997 Views)
Thank you for your help. i correct the VI and it seems to work properly now.
(2,984 Views)
Thanks for your previous help.Now I have another question. Could you help me?
http://forums.ni.com/t5/Counter-Timer/daq-counter-using-gate-input/m-p/1782362
Best wishes.
Yao
(2,915 Views)
