VISA write timing
I have a VISA write in a state machine, and the write was a bit slow.  It was taken out of the machine and placed in a seperate VI for timing analysis.  Affter the VISA write was placed in a different VI, the write duration decreased by 1s.  What reasons could have caused it?  Thanks!
Kudos and Accepted as Solution are welcome!
Message 1 of 8
(4,594 Views)
Not enough information. What sort of physical connection? How many bytes being written? How did you determine the write was the problem? Where's your code?
Message 2 of 8
(4,583 Views)
...and what is the device at the other end of the wire with which you are communicating?
Mike...
Certified LabVIEW Architect
LabVIEW Champion
Message 3 of 8
(4,550 Views)
The instrument is a precise DMM that connects to a GPIB module in a PXI chassis connected to a laptop through an express card.  The command written to the DMM is a string with about 10 characters.  We use a flat sequence structure with the tick node and the 1st and 3rd frame to time the performance of the write node in the 2nd frame.  I don't have the code.  Somebody else is working on it now, but I was pull in to have my brain picked (the NI forum as well).  I am just looking for general advise.  Thank you!
Message 4 of 8
(4,529 Views)
Refer to my previous post.  Thanks!
Message 5 of 8
(4,527 Views)
Well I'm not going to even try to guess. The fact that someone is working on the program seems a poor excuse. Surely you can pull a copy from source code control.
Message 6 of 8
(4,522 Views)
You need to bring the patient in to get a diagosis.
Bill
CLD
(Mid-Level minion.)
Message 7 of 8
(4,507 Views)
ok.  never mind.  He didn't check it into source control.  It is on his PC.  I will let him figure it out or ask it on the forum himself.  Thanks!
Message 8 of 8
(4,466 Views)
