VISA
I'm trying to design a vi that will take information in a HEX format from Docklight and output blood pressure and heart rate.
I've included my requirements as I understand them and my inital attempt at the vi (not very complex I got lost fairly early, and don't have much experience understanding VISA requirments).
I want to be able to "read" through the file (output HEX) and determine when the value is 67 because this is the indication that the sensor has acheived a sucessful measurement. The next three values are the systolic pressure etc. I know how to take the output values and use them as I want.
What I need to know is:
     Do I have to change my valued from HEX in order to read them in the VISA?
     How do a create a loop that reads all the value until it reaches 67?
     How do I initalize a new loop starting at 67 and have it output these values in a way that I can display easily on the front panel?
I'm pretty sure this is straightforward I'm just still getting used to understanding VISA function.
(2,893 Views)
What you are saying does not make much sense. You say you want to read from a file but VISA has nothing to do with file I/O.
(2,884 Views)
I assume you are using Serial VISA?
Check out this tutorial:
https://learn.ni.com/learn/article/getting-started-with-instrument-control-hardware-and-labview
Br,
/Roger
(2,874 Views)
