VISION asssitant display resolution
Hi sir gud evening  small problem please solution
  i have my screen display at 1366*760 but accessing the funtion according to the 1152 * 864 not accessing the funtion   again uninstalling software again update but not solution sir so please me to get it
 screenshot adding this problem sir plz help me solution
(1,880 Views)
Did you look at the last part of the dialog box where it talks about the taskbar?
If you auto-hide the task bar (which seems to be always on in your screen shot), does that solve the problem?
(1,862 Views)
Your vertical display setting of 768 is not enough for Vision Assistant. Choose a display setting with a higher vertical resolution, which is at least 864, such as 1600 x 900, which should give you a similar aspect ratio on your screen.
(1,858 Views)
Is there a bug with the language in that dialog box.
"it should be 11542 x 864 or later"    Shouldn't that say "larger"?
(1,798 Views)
