VIT embedded in webservice
Dear NI
I have embedded the VIT in labview webservice(using vi publishing tecnique not exactly but take the idea of vi publishing).
this VIT is shown on some page.
When i check in development mode the VIT successfully embed and works fine.
But when i made executeable of my application the message come on webpage that the requested vi is not loaded into memory.
please help me in this regard.
regards
(2,593 Views)
mazhar, unfortunately I'm not familiar with VIT. If this is close to our VI publishing technique then perhaps one of this resources might give you a clue:
- How Do I Enable LabVIEW Web Server or Use Remote Panels With an Executable Built in LabVIEW?
I hope this helps
Alejandro C. | National Instruments
(2,571 Views)
thanx a lot alcava. cr i have fixed my problem and thanxs for your intrest n time. problem is due to ports reservation which is now fixed.
regards
(2,563 Views)
