This widget could not be displayed.
VIs Breaking When BD is Removed
When you save a VI without its block diagram using this
it might be broken after you close, then reopen it.
I have discovered the following things that can cause that:
  1. An uninitialized shift register containing a class (seems to depend on what's in the mutation history)
  2. A polymorphic subVI that references a VI that needs compiling.
There are probably other things, but those are the only two I've found (so far).
Message 1 of 1
(993 Views)
